System variables
If you want to make a setting change for the current session and also make that setting change apply to all future sessions, you can make the change twice, once without the
GLOBALmodifier and once with it. For example:SET query_mem_limit = 137438953472; -- Apply to the current session.
Variable hierarchy and typesβ
- Global variables take effect on global level, and can be overridden by session variables and
SET_VARhints. - Session variables take effect only on the current session, and can be overridden by
SET_VARhints. SET_VARhints take effect only on the current query statement.
View variablesβ
SHOW VARIABLES;
Set variablesβ
Set variables globally or for a single sessionβ
SET forward_to_master = true;
- activate_all_roles_on_login
- character_set_database
- cngroup_low_watermark_cpu_used_permille
- cngroup_low_watermark_running_query_count
- cngroup_resource_usage_fresh_ratio
- cngroup_schedule_mode
- default_rowset_type
- enable_reduce_cast_varchar_expr_sync_type
- enable_reduce_cast_varchar_length_inheritance
- enable_group_level_query_queue
- enable_query_history
- enable_query_queue_load
- enable_query_queue_select
- enable_table_name_case_insensitive
- enable_tde
- init_connect
- language
- license
- lower_case_table_names
- performance_schema
- query_cache_size
- query_history_keep_seconds
- query_history_load_interval_seconds
- query_queue_driver_high_water
- query_queue_driver_low_water
- system_time_zone
- version
- version_comment
Set variables in a single query statementβ
- SELECT
- INSERT (from v3.1.12 and v3.2.0 onwards)
- UPDATE (from v3.1.12 and v3.2.0 onwards)
- DELETE (from v3.1.12 and v3.2.0 onwards)
Example:
FROM my_table PARTITION p1
WHERE k1 = 3;
INTO insert_wiki_edit
SELECT * FROM FILES(
"format" = "parquet",
"aws.s3.region" = "us-west-2"
SELECT /*+ SET_VAR
query_timeout=10000000,
batch_size=4096,
*/ * FROM TABLE;
Set variables as user propertiesβ
Example:
Descriptions of variablesβ
activate_all_roles_on_login (global)β
- Description: Whether to enable all roles (including default roles and granted roles) for a StarRocks user when the user connects to the StarRocks cluster.
- If enabled (
true), all roles of the user are activated at user login. This takes precedence over the roles set by SET DEFAULT ROLE. - If disabled (
false), the roles set by SET DEFAULT ROLE are activated.
- If enabled (
- Default: false
- Introduced in: v3.0
array_low_cardinality_optimizeβ
- Scope: Session
- Description: Controls whether the optimizer will consider ARRAY<VARCHAR> columns for low-cardinality (dictionary-based) decoding and related optimizations. When enabled, the optimizer's low-cardinality rules (for example,
DecodeCollector) may define dictionary columns and apply dictionary decoding to expressions whose type is VARCHAR or ARRAY<VARCHAR>. When disabled, only scalar VARCHAR columns are eligible and ARRAY<VARCHAR> types are ignored by those low-cardinality optimizations. - Default: true
- Data Type: boolean
- Introduced in: v3.3.0, v3.4.0, v3.5.0
authentication_policyβ
- Scope: Session
- Description: Session-level variable that holds the raw authentication policy string (kept for MySQL 8.0 compatibility). It is declared and stored on the FE as part of the session state and exposed under the name
authentication_policy. In the current codebase snapshot the value is stored as an opaque comma-separated string and there is no other usage or internal parsing of this field in FE (it is not referenced elsewhere). It is related to thedefault_authentication_pluginsession variable:authentication_policyrepresents per-session authentication policy data whiledefault_authentication_pluginindicates the default authentication plugin. Administrators or clients can set this variable per session (for example withSET authentication_policy = '...') to preserve compatibility with MySQL clients or tooling. - Default:
*,, - Data Type: String
- Introduced in: -
binary_encoding_formatβ
- Scope: Session
- Description: Controls how
BINARY/VARBINARYvalues are encoded when StarRocks serializes MySQL text results. Valid values areraw,hex, andbase64. The default ishex. This variable works together withbinary_encoding_level. MySQL clients can already handle top-level binary values, but nested binary values insideARRAY,MAP, orSTRUCTare returned through JSON-like strings, so they may need extra encoding to stay printable and well-formed. Set this variable tobase64if you prefer a denser printable representation, orrawto disable extra encoding entirely. - Default:
hex - Data Type: String
- Introduced in: v4.1
binary_encoding_levelβ
- Scope: Session
- Description: Controls which binary values are encoded for MySQL text results. Valid values are
nestedandall. The default isnested, which preserves historical behavior for top-level binary columns while still encoding nested binary values insideARRAY,MAP, orSTRUCT, where the result is rendered as a JSON-like string. Set this variable toallif your team wants a uniform convention and prefers top-level binary values to be encoded as well. Ifbinary_encoding_format = raw, no additional binary encoding is applied even when this variable is set tonestedorall, which may make nested output less readable. - Default:
nested - Data Type: String
auto_increment_incrementβ
avro_use_jni_readerβ
Scope: Session
Description: Controls whether StarRocks uses the JNI-based Avro reader when scanning Avro data from external catalogs such as Hive. When enabled (
true), the FE sets this session variable on Avro scan ranges and the BE choosesHdfsAvroScannerinstead of the native Avro scanner path. This option can be used as a compatibility fallback when the native reader does not meet your needs.Current limitation:
CHAR(n)columns are not fully compatible between the JNI and non-JNI Avro readers. For Avro values such asCharread into aCHAR(10)column, the current native reader keeps the unpadded value instead of returningCharfollowed by six spaces, while the JNI reader may behave differently. To avoid inconsistent results, we recommend not relying onCHAR(n)padding semantics when switchingavro_use_jni_reader, and usingVARCHARinstead when possible. -
Default:
true -
Data Type: boolean
Introduced in: v4.1.1
big_query_profile_thresholdβ
Description: Used to set the threshold for big queries. When the session variable
enable_profileis set tofalseand the amount of time taken by a query exceeds the threshold specified by the variablebig_query_profile_threshold, a profile is generated for that query.Note: In versions v3.1.5 to v3.1.7, as well as v3.2.0 to v3.2.2, we introduced the
big_query_profile_second_thresholdfor setting the threshold for big queries. In versions v3.1.8, v3.2.3, and subsequent releases, this parameter has been replaced bybig_query_profile_thresholdto offer more flexible configuration options. -
Default: 0
Unit: Second
Data type: String
Introduced in: v3.1
blacklist_backup_routingβ
- Scope: Session
- Description: In shared-data mode, if the compute node the plan prefers for a scan is not among the workers available to the current query (for example, the node is down or appears on the host blocklist), the planner must choose a backup compute node. This variable sets how that backup is chosen among eligible nodes (other than the primary).
RANDOMsamples uniformly at random from the eligible set.CIRCULARwalks the sorted compute node id ring from the primary and takes the first eligible node (deterministic). Which nodes are eligible for backup also depends onskip_black_list: by default, nodes on the host blocklist are excluded; ifskip_black_lististrue, a node that is on the blocklist may still be chosen as a backup when it is otherwise available (for example, alive and in the warehouse). - Default:
CIRCULAR - Data type: String
- Valid values:
CIRCULAR,RANDOM - Introduced in: -
broadcast_row_limitβ
- Scope: Session
- Description: Limits the right-side table's output row count for a broadcast join. The optimizer (see
EnforceAndCostTask) treats a candidate as ineligible for broadcast when the right table's row count exceeds this limit or when combined size/scale checks indicate the right table is not sufficiently smaller than the left. A nonβpositive value disables this limit.PushDownAggregateCollectoralso uses this variable to identify "small broadcast" joins for aggregate pushβdown: it requires the rightRows less than or equal to this limit and less than or equal tocbo_push_down_aggregate_on_broadcast_join_row_count_limitbefore allowing pushβdown. It interacts withbroadcast_right_table_scale_factorand the number of BE nodes when comparing left/right sizes. For example, whenleftOutputSizeis less thanrightOutputSize * beNum * broadcast_right_table_scale_factorandrightRowCountis greater thanbroadcast_row_limit, broadcast is rejected. - Default:
15000000 - Data Type: long
- Introduced in: v3.2.0
catalogβ
- Description: Used to specify the catalog to which the session belongs.
- Default: default_catalog
- Data type: String
- Introduced in: v3.2.4
cbo_cte_force_reuse_node_countβ
- Description: Session-scoped threshold that controls an optimizer shortcut for Common Table Expressions (CTEs). In RelationTransformer.visitCTE the planner counts nodes in a CTE producer tree (cteContext.getCteNodeCount). If that count is greater than or equal to this threshold and the threshold is greater than 0, the transformer forces reuse of the CTE: it skips inlining/transforming the producer plan, builds a consume operator with precomputed expression mappings (no inputs) and uses generated column refs instead. This reduces optimizer time for very large CTE producer trees at the cost of potentially less optimal physical plans. Setting the value to
0disables the force-reuse optimization. This variable has a getter/setter in SessionVariable and is applied per session. - Scope: Session
- Default:
2000 - Data Type: int
- Introduced in: v3.5.3
cbo_cte_reuseβ
- Description: Controls whether the optimizer may rewrite multi-distinct aggregate queries by reusing a Common Table Expression (CTE) (the CBO CTEβreuse rewrite). When enabled, the planner (RewriteMultiDistinctRule) may choose a CTE-based rewrite for multi-column distincts, skewed aggregations, or when statistics indicate the CTE rewrite is more efficient; it also respects the
prefer_cte_rewritehint. When disabled, CTE-based rewrite is not allowed and the planner will attempt the multi-function rewrite; if a query requires CTE (for example, multi-column DISTINCT or functions that cannot be handled by multi-function rewrite) the planner will raise a user error. Note: the effective setting checked by the optimizer is the logical AND of this flag and the pipeline engine flag β i.e.isCboCteReuse()returns this variable ANDenablePipelineEngine, so CTE reuse is only effective whenenablePipelineEngineis on. - Default:
true - Data Type: Boolean
- Introduced in:
v3.2.0
cbo_disabled_rulesβ
- Description: Comma-separated list of optimizer rule names to disable for the current session. Each name must match a
RuleTypeenum value and only rules whose names start withTF_(transformation rules) orGP_(group-combination rules) may be disabled. The session variable is stored onSessionVariable(getCboDisabledRules/setCboDisabledRules) and is applied by the optimizer viaOptimizerOptions.applyDisableRuleFromSessionVariable(), which parses the list and clears the corresponding rule switches so those rules are skipped during planning. When set through a SET statement, values are validated and the server will reject unknown names or names not starting withTF_/GP_with clear error messages (e.g. "Unknown rule name(s): ..." or "Only TF_ ... and GP_ ... can be disabled"). At planner runtime, unknown rule names are ignored with a warning (logged as "Ignoring unknown rule name: ... (may be from different version)"). Names must match enum identifiers exactly (case-sensitive). Whitespace around names is trimmed; empty entries are ignored. - Scope: Session
- Default:
""(no disabled rules) - Data Type: String
- Introduced in: -
cbo_enable_low_cardinality_optimizeβ
- Description: Whether to enable low cardinality optimization. After this feature is enabled, the performance of querying STRING columns improves by about three times.
- Default: true
cbo_enable_low_cardinality_optimize_for_joinβ
- Scope: Session
- Description: Controls whether the optimizer rewrites join operators to take advantage of low-cardinality (dictionary-encoded) string columns. When enabled (default), the optimizer (DecodeCollector / DecodeRewriter) will:
- rewrite join ON predicates, join predicates and projections to use dictionary-encoded column refs for low-cardinality string columns (affects hash joins);
- extract equality groups for join columns and enable decoding-based optimizations for supported join patterns. When disabled, join-related low-cardinality rewrites are skipped and string columns are left unchanged for join processing. Note: the implementation currently targets broadcast joins and avoids rewrite when both sides use shuffle distribution.
- Default:
true - Data Type: boolean
- Introduced in: -
cbo_eq_base_typeβ
- Description: Specifies the data type used for data comparison between DECIMAL data and STRING data. The default value is
DECIMAL, and VARCHAR is also a valid value. This variable takes effect only for=and!=comparison. - Data type: String
- Introduced in: v2.5.14
cbo_json_v2_dict_optβ
- Description: Whether to enable low-cardinality dictionary optimization for Flat JSON (JSON v2) extended string subcolumns created by JSON path rewrite. When enabled, the optimizer may build and use global dictionaries for those subcolumns to accelerate string expressions, GROUP BY, and JOIN operations.
- Default: true
- Data type: Boolean
cbo_json_v2_rewriteβ
- Description: Whether to enable JSON v2 path rewrite in the optimizer. When enabled, JSON functions (such as
get_json_*) can be rewritten to direct access of Flat JSON subcolumns, enabling predicate pushdown, column pruning, and dictionary optimization. - Default: true
cbo_max_reorder_node_use_dpβ
- Description: Session-scoped limit that controls when the cost-based optimizer (CBO) will include the DP (dynamic programming) join-reorder algorithm. The optimizer compares the number of join inputs (MultiJoinNode.atoms.size()) against this value and only runs or adds the DP reorder when
multiJoinNode.getAtoms().size() <= cbo_max_reorder_node_use_dpandcbo_enable_dp_join_reorderis enabled. Used in JoinReorderFactory.createJoinReorderAdaptive (to add JoinReorderDP to the candidate algorithms) and in ReorderJoinRule.transform/rewrite (to decide whether to execute JoinReorderDP when copying plans into the memo). Default value 10 reflects a practical performance cutoff (comment in code: "10 table join reorder takes more than 100ms"). Tune this to trade optimizer runtime (DP is expensive) versus potential plan quality for larger multi-join queries. Interacts withcbo_enable_dp_join_reorderand the greedy thresholdcbo_max_reorder_node_use_greedy. The comparison is inclusive (<=). - Scope: Session
- Default:
10 - Data Type: long
- Introduced in:
v3.2.0
cbo_max_reorder_node_use_exhaustiveβ
- Scope: Session
- Description: Controls the join-reorder algorithm selection threshold in the CBO. The optimizer counts inner/cross join nodes in the query; when that count is greater than this value the planner takes the transform-based (more aggressive) reorder path: it forces collection of CTE statistics and calls ReorderJoinRule.transform and related commutativity rules. When the count is less than or equal to this value the planner applies the cheaper join-transformation rules (and may add the INNER_JOIN_LEFT_ASSCOM_RULE for certain semi/anti-join cases). This session variable is read by the optimizer (
SPMOptimizer,QueryOptimizer) and can be set at the session level viasetMaxTransformReorderJoins. - Default:
4 - Data Type: int
cbo_max_reorder_node_use_greedyβ
- Description: Maximum number of join inputs (atoms) in a multi-join for which the cost-based optimizer will consider the greedy join-reorder algorithm. The optimizer checks this limit (together with
cbo_enable_greedy_join_reorder) when building the list of candidate reorder algorithms: ifmultiJoinNode.getAtoms().size()is less than or equal to this value, aJoinReorderGreedyinstance will be added and executed. This variable is used byJoinReorderFactory.createJoinReorderAdaptive()andReorderJoinRuleto gate greedy reordering during join-reorder phases; it applies per session and affects whether greedy reordering is attempted (if statistics are available and greedy is enabled). Adjust this to control optimizer time/complexity trade-offs for queries with many joined relations. - Scope: Session (can be changed per-session)
- Default:
16 - Data type: long
- Introduced in: v3.4.0, v3.5.0
cbo_prune_json_subfieldβ
- Scope: Session
- Description: When enabled, the cost-based optimizer collects and prunes JSON subfield expressions so that JSON access paths (subfields) are recognized and converted into ColumnAccessPath for scan operators. This enables flat-JSON path optimizations and push-down of JSON subfield access into the scan layer (see PruneSubfieldRule and SubfieldExpressionCollector). Note: normalization of cast-from-JSON expressions is gated by the general
cbo_prune_subfieldoptimization; both work together to produceget_json_xxx(...)or cast-wrapped calls so BE can apply flat JSON optimizations. Enablingcbo_prune_json_subfieldwithout backend support forflat jsonmay degrade performance; disable it if the BE does not support flat JSON path pushdown. - Default:
true - Data type: boolean
cbo_use_correlated_predicate_estimateβ
- Description: Session flag that controls whether the optimizer applies a correlation-aware heuristic when estimating selectivity for conjunctive equality predicates across multiple columns. When enabled (default), the estimator applies exponential-decay weights to the selectivities of additional columns beyond the primary multi-column stats or most selective predicate, reducing the multiplicative impact of further predicates (weights: 0.5, 0.25, 0.125 for up to three additional columns). When disabled, no decay is applied (decay factor = 1) and the estimator multiplies full selectivities for those columns (stronger independence assumption). This flag is checked by StatisticsEstimateUtils.estimateConjunctiveEqualitySelectivity to choose the decay factor in both the multi-column-statistics path and the fallback path, thereby affecting cardinality estimates used by the CBO.
- Scope: Session
- Default:
- Introduced in: v3.5.0
character_set_database (global)β
- Data type: StringThe character set supported by StarRocks. Only UTF8 (
utf8) is supported. - Default: utf8
- Data type: String
collation_connectionβ
- Description: Session-scoped variable that stores the connection collation name for the current client session. It is declared in
SessionVariableascollationConnectionand exposed with the show-namecollation_connection. The variable is surfaced in metadata and SHOW outputs (for example, used when buildingSHOW CREATE VIEWrows inShowExecutorand returned as a constant forinformation_schema.viewsviaViewsSystemTable.CONSTANT_MAP). It represents the collation reported by the server for the connection (paired withcharacter_set_clientand related character-set variables) but does not by itself indicate runtime collation enforcement beyond what other components implement. - Scope: Session
- Default:
utf8_general_ci - Data Type: String
collation_databaseβ
- Description: Session-level variable that holds the default database collation name for the current session. It is declared in SessionVariable (annotated with
@VariableMgr.VarAttr) and lives alongside other charset/collation session variables such ascharacter_set_client,collation_connectionandcollation_server. The value is serialized when session variables are exported (e.g., included in the JSON produced by SessionVariable#getJsonString and in the session variable machinery), and is used to report the session's database collation. Changing this variable updates the session's reported database collation name; engine-level or object-level collation settings (server/table/column) may still take precedence for actual comparison/ordering behavior depending on context. - Scope: Session
- Default:
collation_serverβ
- Scope: Session
- Description: Session-level server collation name used by the FE to present MySQL-compatible collation behavior for this session. This variable sets the default collation identifier (for example
utf8_general_ci) that FE reports to clients and that is associated withcharacter_set_server/collation_connection/collation_database. It is persisted in the session variable JSON (see SessionVariable#getJsonString / replayFromJson) and is exposed via the variable manager (@VarAttr(name = COLLATION_SERVER)), so it appears in SHOW VARIABLES and can be changed per-session. The value is stored as a plain String in SessionVariable and typically holds a standard MySQL collation name (e.g.utf8_general_ci,utf8mb4_unicode_ci); the code does not enforce a fixed enum or perform additional validation here, so the effective behavior depends on downstream components that interpret the collation name for comparisons, ordering and other collation-sensitive operations. - Default Value:
- Introduced in:
v3.2.0
computation_fragment_scheduling_policyβ
- Scope: Session
- Description: Controls the scheduler policy used to choose execution instances for computation fragments. Valid values (case-insensitive) are:
compute_nodes_onlyβ schedule fragments only on compute nodes (default).all_nodesβ allow scheduling on both compute nodes and traditional backend nodes. The variable is backed by the enumSessionVariableConstants.ComputationFragmentSchedulingPolicy. When set, the value is validated (upper-cased) against the enum; invalid values cause an error (IllegalArgumentExceptionwhen set via API,SemanticExceptionwhen used in a SET statement). The getter returns the corresponding enum value and falls back toCOMPUTE_NODES_ONLYif unset or unrecognized. This setting affects how the FE chooses target nodes for fragment placement at planning/deployment time.
- Default:
COMPUTE_NODES_ONLY - Data Type: String
- Introduced in: v3.2.7
connector_io_tasks_per_scan_operatorβ
- Description: The maximum number of concurrent I/O tasks that can be issued by a scan operator during external table queries. The value is an integer. Currently, StarRocks can adaptively adjust the number of concurrent I/O tasks when querying external tables. This feature is controlled by the variable
enable_connector_adaptive_io_tasks, which is enabled by default. - Default: 16
- Data type: Int
connector_sink_compression_codecβ
- Description: Specifies the compression algorithm used for writing data into Hive tables or Iceberg tables, or exporting data with Files(). This parameter only takes effect in the following situations:
- The
compression_codecproperty does not exist in the Hive tables. - The
write.parquet.compression-codecproperties do not exist in the Iceberg tables. - The
compressionproperty is not set forINSERT INTO FILES.
- The
- Valid values:
uncompressed,snappy,lz4,zstd, andgzip. - Default: uncompressed
- Data type: String
- Introduced in: v3.2.3
connector_sink_target_max_file_sizeβ
- Description: Specifies the maximum size of target file for writing data into Hive tables or Iceberg tables, or exporting data with Files(). The limit is not exact and is applied on a best-effort basis.
- Unit: Bytes
- Default: 1073741824
- Data type: Long
count_distinct_column_bucketsβ
- Description: The number of buckets for the COUNT DISTINCT column in a group-by-count-distinct query. This variable takes effect only when
enable_distinct_column_bucketizationis set totrue. - Default: 1024
custom_query_id (session)β
- Description: Used to bind some external identifier to a current query. Can be set using
SET SESSION custom_query_id = 'my-query-id';before executing a query. The value is reset after query is finished. This value can be passed toKILL QUERY 'my-query-id'. Value can be found in audit logs as acustomQueryIdfield. - Default: ""
- Data type: String
custom_session_name (session)β
- Description: Used to specify custom name of current session, analog of
applicationNameorprogram_namein DMBS like MySQL or PostgreSQL. Can be set usingSET SESSION custom_session_name = 'my session name';. Value can be found in audit logs incustomSessionNamefield. - Default: ""
- Data type: String
- Introduced in: v4.1.0
datacache_sharing_work_periodβ
- Description: The period of time that Cache Sharing takes effect. After each cluster scaling operation, only the requests within this period of time will try to access the cache data from other nodes if the Cache Sharing feature is enabled.
- Default: 600
- Unit: Seconds
- Introduced in: v3.5.1
decimal_overflow_to_doubleβ
- Scope: Session
- Description: When enabled, the analyzer converts decimal arithmetic results that would overflow the maximum decimal precision into 64-bit floating point (
DOUBLE) instead of widening to larger decimal types or failing. Concretely, in DecimalV3 arithmetic (see DecimalV3FunctionAnalyzer), if a multiplication's computed precision exceeds the engine's max decimal precision but its return scale is within the maximum, the session flagdecimal_overflow_to_double = truecauses the return type and operand target types to be set toDOUBLE. This yields an approximate (lossy) numeric result but avoids decimal precision overflow errors or forced use of larger decimal types. When false (default), the planner will keep decimal semantics (attempt decimal128/256 or throw on unrepresentable scale/precision). - Default:
false - Data Type: boolean
- Introduced in: -
default_authentication_pluginβ
- Scope: Session
- Description: Session-scoped variable that specifies the default MySQL authentication plugin name for this session. It is stored as SessionVariable.defaultAuthenticationPlugin and is used by StarRocks' MySQL-protocol compatibility layers when the server needs to advertise or use a default authentication plugin (for example during handshake or when a plugin is not specified). Accepts standard MySQL authentication plugin identifiers (e.g.
mysql_native_password,caching_sha2_password) supported by the server. This variable affects session behavior only; persistent user account authentication configuration is managed separately. See related session variableauthentication_policy. - Default:
mysql_native_password - Data Type: String
- Introduced in: -
default_rowset_type (global)β
default_storage_engineβ
- Scope: Session
- Description: Session system variable exposed as
default_storage_engine(see SessionVariable VarAttr). It exists for MySQL 8.0 compatibility and to satisfy MySQL clients/libraries that query the session default storage engine. The variable is stored per-session in the SessionVariable object and is returned to clients (e.g., via SHOW VARIABLES). It is informational for compatibility; changing it adjusts the session-reported value but does not imply StarRocks will change internal storage implementation. - Default:
InnoDB - Data Type: String
- Introduced in: v3.4.2, v3.5.0
default_table_compressionβ
Description: The default compression algorithm for table storage. Supported compression algorithms are
snappy, lz4, zlib, zstd.Note that if you specified the
compressionproperty in a CREATE TABLE statement, the compression algorithm specified bycompressiontakes effect. -
Default: lz4_frame
Introduced in: v3.0
default_tmp_storage_engineβ
- Description: Session variable that controls the default storage engine used for temporary tables (both explicit
CREATE TEMPORARY TABLEand internal/implicit temporary tables created by the engine). Declared inSessionVariable.javawith a@VariableMgr.VarAttrannotation, it exists primarily for MySQL 8.0 compatibility so clients and tools expecting MySQL-like behavior can observe or change the temporary-table engine per session. Changing this value affects how temporary table data is stored/managed on storage layers that honor different engines (for example, choosing between memory-backed vs. disk-backed engines). - Scope: Session
- Default:
disable_colocate_joinβ
- Description: Used to control whether the Colocation Join is enabled. The default value is
false, meaning the feature is enabled. When this feature is disabled, query planning will not attempt to execute Colocation Join. - Default: false
disable_colocate_setβ
- Scope: Session
- Description: When false (default), the optimizer may apply "colocate set" handling for set operations (e.g., UNION / UNION DISTINCT) when the first child's hash distribution is local: the planner attempts to keep children colocated β avoiding full repartitioning by checking pairwise colocation and either converting to compatible bucket shuffles or keeping colocated execution. When true, this session flag disables that colocate-set optimization path; the planner will not rely on colocated-set guarantees and will instead fall back to converting the set operation to round-robin distribution or enforce explicit bucket shuffle conversions for non-colocated children. This flag is consulted by the planner (see ChildOutputPropertyGuarantor.visitPhysicalSetOperation) and exposed on the session via SessionVariable getter/setter (
isDisableColocateSet/setDisableColocateSet). - Default:
disable_join_reorderβ
- Scope: Session
- Description: Controls whether the cost-based optimizer performs join reordering. When
false(default) the optimizer may apply join-reorder transformations (e.g.ReorderJoinRule, join transformation and outer-join transformation rules) during logical optimization in the new planner paths (seen inSPMOptimizerandQueryOptimizer). Whentrue, join reordering and related outer-join reorder rules are skipped, preventing the optimizer from changing join order. This is useful to reduce optimization time, to obtain stable/reproducible join ordering, or to work around cases where CBO reordering produces suboptimal plans. This setting interacts with other CBO/session controls such ascbo_max_reorder_node,cbo_max_reorder_node_use_exhaustive, andenable_outer_join_reorder. - Default:
disable_spill_to_local_diskβ
- Description: When set to
truefor the session, FE will instruct BE to disable spilling to local disk and instead rely on remote storage spill (if remote spill is configured). This flag is only meaningful whenenable_spill=true,enable_spill_to_remote_storage=true, and a validspill_storage_volumeis provided and found by FE. The value is serialized into TSpillToRemoteStorageOptions (sent to BE) asdisable_spill_to_local_disk. If remote spill is not configured or the named storage volume cannot be resolved, this setting has no effect. Use with caution: disabling local-disk spill can increase network I/O and latency and requires reliable, performant remote storage. - Scope: Session
- Default: false
div_precision_incrementβ
dynamic_overwriteβ
- Description: Whether to enable the Dynamic Overwrite semantic for INSERT OVERWRITE with partitioned tables. Valid values:
true: Enables Dynamic Overwrite.false: Disables Dynamic Overwrite and uses the default semantic.
- Default: false
enable_adaptive_sink_dopβ
- Description: Specifies whether to enable adaptive parallelism for data loading. After this feature is enabled, the system automatically sets load parallelism for INSERT INTO and Broker Load jobs, which is equivalent to the mechanism of
pipeline_dop. For a newly deployed v2.5 StarRocks cluster, the value istrueby default. For a v2.5 cluster upgraded from v2.4, the value isfalse. - Default: false
enable_bucket_aware_execution_on_lakeβ
- Description: Whether to enable bucket-aware execution for queries against data lakes (such as Iceberg tables). When this feature is enabled, the system optimizes query execution by leveraging bucketing information to reduce data shuffling and improve performance. This optimization is particularly effective for join operations and aggregations on bucketed tables.
- Default: true
- Introduced in: v4.0
enable_cbo_based_mv_rewriteβ
- Description: Whether to enable materialized view rewrite in CBO phase which can maximize the likelihood of successful query rewriting (e.g., when the join order differs between materialized views and queries), but it will increase the execution time of the optimizer phase.
- Default: true
- Introduced in: v3.5.5, v4.0.1
enable_cbo_table_pruneβ
- Description: When enabled, the optimizer will add the CBO table pruning rule (CboTablePruneRule) during memo optimization to perform cost-based table pruning for cardinality-preserving joins. The rule is conditionally added in the optimizer (see QueryOptimizer.memoOptimize and SPMOptimizer.memoOptimize) only when the join-node count in the join tree is small (fewer than 10 join nodes). This option complements the rule-based pruning toggle
enable_rbo_table_pruneand lets the Cost-Based Optimizer try to remove unnecessary tables or inputs from join processing to reduce planning and execution complexity. Default is off because pruning can change plan shape; enable it only after validating on representative workloads. - Scope: Session
- Default:
enable_cache_udafβ
true, enables in-memory caching of the class-level Java UDAF initialization (class loading, method introspection, and batch-update stub generation). The cache is populated on first use and reused across all aggregator/analytor instances within the same BE process, eliminating the repeated per-instance initialization overhead that is otherwise proportional to pipeline DOP. Caching only applies to UDAFs and window functions that were created with"isolation" = "shared". Functions created with"isolation" = "private"always go through the uncached path regardless of this setting. Default isfalse; enable after verifying that shared-isolation UDAFs are safe to share their class-level state across concurrent queries. The runtime profile exposesUdafCacheHitCount,UdafCachePopulateCount, andUdafLoadTimecounters to observe cache behavior. - Scope: Session
- Default:
enable_color_explain_outputβ
- Scope: Session
- Description: Controls whether ANSI color escape sequences are included in textual EXPLAIN / PROFILE outputs. When enabled (
true), StmtExecutor passes the session setting into the explain/profile pipeline (via calls to ExplainAnalyzer) so explain, EXPLAIN ANALYZE and analyze-profile outputs contain colored highlighting for readability in ANSI-capable terminals. When disabled (false), the output is produced without ANSI sequences (plain text), which is appropriate for logging, clients that do not support ANSI, or when piping output to files. This is a per-session toggle and does not change execution semanticsβonly the presentation of explain/profile text. - Default:
enable_connector_adaptive_io_tasksβ
- Description: Whether to adaptively adjust the number of concurrent I/O tasks when querying external tables. Default value is
true. If this feature is not enabled, you can manually set the number of concurrent I/O tasks using the variableconnector_io_tasks_per_scan_operator. - Default: true
enable_cost_based_multi_stage_aggβ
- Description: Controls whether the new planner uses cost-based decisions to generate and compare multi-stage aggregation plans for queries with DISTINCT aggregates. When enabled, the optimizer may produce alternative 3-stage and 4-stage aggregation candidates and rely on cost estimates to pick the better plan. It also enables post-processing in
PruneAggregateNodeRuleto merge or prune split aggregate nodes when beneficial (that is, reducing unnecessary serialization or deserialization). Note that the effective check in code is gated bynew_planner_agg_stageβ the helperisEnableCostBasedMultiStageAgg()returns true only whennew_planner_agg_stageis set toAUTOand this parameter is set totrue; ifnew_planner_agg_stageis non-AUTO, this parameter will not enable cost-based multi-stage behavior. Disabling this flag forces the planner to prefer the simpler 3-stage transformation for distinct aggregations and skips cost-driven candidate generation and certain aggregate-node merges. - Scope: Session
- Default:
- Introduced in: -
enable_datacache_async_populate_modeβ
- Description: Whether to populate the data cache in asynchronous mode. By default, the system uses the synchronous mode to populate data cache, that is, populating the cache while querying data.
- Default: false
enable_datacache_io_adaptorβ
- Description: Whether to enable the Data Cache I/O Adaptor. Setting this to
trueenables the feature. When this feature is enabled, the system automatically routes some cache requests to remote storage when the disk I/O load is high, reducing disk pressure. - Default: true
enable_datacache_sharingβ
- Description: Whether to enable Cache Sharing. Setting this to
trueenables the feature. Cache Sharing is used to support accessing cache data from other nodes through the network, which can help to reduce performance jitter caused by cache invalidation during cluster scaling. This variable takes effect only when the FE parameterenable_trace_historical_nodeis set totrue. - Default: true
enable_distinct_agg_over_windowβ
- Description: Controls the optimizer rewrite that transforms DISTINCT aggregate calls over WINDOW clauses into an equivalent join-based plan. When enabled (
true, the default) QueryOptimizer.invoke convertDistinctAggOverWindowToNullSafeEqualJoin will:- detect queries containing a LogicalWindowOperator,
- run project-merge rewrites, derive logical properties,
- apply DistinctAggregationOverWindowRule to convert the DISTINCT-OVER-WINDOW pattern into a null-safe equality join (changing plan shape to enable further push-downs and aggregation optimizations),
- then run SeparateProjectRule and re-derive properties.
When disabled (
false) the optimizer skips this transformation and leaves DISTINCT aggregates over windows unchanged. This setting is session-scoped and affects only the optimizer rewrite phase (see QueryOptimizer.convertDistinctAggOverWindowToNullSafeEqualJoin).
- Default:
- Introduced in: -
enable_distinct_column_bucketizationβ
Description: Whether to enable bucketization for the COUNT DISTINCT colum in a group-by-count-distinct query. Use the
select a, count(distinct b) from t group by a;query as an example. If the GROUP BY columais a low-cardinality column and the COUNT DISTINCT columnbis a high-cardinality column which has severe data skew, performance bottleneck will occur. In this situation, you can split data in the COUNT DISTINCT column into multiple buckets to balance data and prevent data skew. You must use this variable with the variablecount_distinct_column_buckets.You can also enable bucketization for the COUNT DISTINCT column by adding the
skewhint to your query, for example,select a,count(distinct [skew] b) from t group by a;. -
Default: false, which means this feature is disabled.
Introduced in: v2.5
enable_eliminate_aggβ
- Description: Controls optimizer transformations that remove or simplify aggregation operators when it is safe to do so. When enabled, the planner applies rules (EliminateAggRule and EliminateAggFunctionRule) to replace a LogicalAggregationOperator with a LogicalProjectOperator (and optionally a LogicalFilterOperator) in two cases:
- Whole-aggregation elimination (EliminateAggRule): when grouping keys form a unique key on the child (unique/UKFK constraints) and all aggregate calls are supported, non-distinct functions (SUM, COUNT, AVG, FIRST_VALUE, MAX, MIN, GROUP_CONCAT). COUNT is rewritten to an IF/CAST expression (COUNT(col) -> IF(col IS NULL, 0, 1); COUNT(*) -> 1).
- Per-function elimination (EliminateAggFunctionRule): when individual non-distinct aggregate functions over a grouped column (FIRST_VALUE, LAST_VALUE, ANY_VALUE, MAX, MIN) can be replaced by the column itself while preserving other aggregations. The optimization requires non-empty group-by keys, supported function sets, and presence of relevant unique constraints or column relationships; it does not apply to DISTINCT aggregates.
- Scope: Session
- Default:
- Introduced in: v3.3.8, v3.4.0, v3.5.0
enable_filter_unused_columns_in_scan_stageβ
- Description: Controls pruning of columns produced by Scan nodes so the scan stage only outputs columns that are actually needed downstream (either as outputs or for non-pushable predicates). When enabled, PlanFragmentBuilder.setUnUsedOutputColumns will mark scan output columns that are exclusively used in pushdownable predicates and not required later, allowing the scan to trim those columns and reduce I/O and network transfer. The pruning is guarded: it will not apply for aggregation-family indexes in the non-skip-aggregation (non-skip-aggr) scan stage (keys/value columns must be retained to merge/aggregate), and the planner always ensures at least one column is returned from a scan. See
isEnableFilterUnusedColumnsInScanStage()and the enable/disable helpersenableTrimOnlyFilteredColumnsInScanStage()/disableTrimOnlyFilteredColumnsInScanStage()in SessionVariable. - Scope: Session
- Default:
enable_force_rule_based_mv_rewriteβ
- Description: Whether to enable query rewrite for queries against multiple tables in the optimizer's rule-based optimization phase. Enabling this feature will improve the robustness of the query rewrite. However, it will also increase the time consumption if the query misses the materialized view.
- Default: true
enable_gin_filterβ
- Description: Whether to utilize the fulltext inverted index during queries.
- Default: true
enable_global_runtime_filterβ
enable_group_by_compressed_keyβ
- Description: Whether to use accurate statistical information to compress the GROUP BY Key column. Valid values:
trueandfalse. - Default: true
enable_group_executionβ
- Description: Whether to enable Colocate Group Execution. Colocate Group Execution is an execution pattern that leverages physical data partitioning, where a fixed number of threads sequentially process their respective data ranges to enhance locality and throughput. Enabling this feature can reduce memory usage.
- Default: true
enable_group_level_query_queue (global)β
- Description: Whether to enable resource group-level query queue.
- Default: false, which means this feature is disabled.
- Introduced in: v3.1.4
enable_incremental_mvβ
- Description: Session flag that controls whether the server will plan and keep an in-memory plan for materialized views that use incremental refresh. When enabled,
MaterializedViewAnalyzer.planMVQuerywill proceed for create-MV statements whose refresh scheme is anIncrementalRefreshSchemeDesc: it builds the logical and physical plan for the view query and sets the sessionenableMVPlannerflag (setMVPlanner(true)). When disabled, planning for incremental-refresh MVs is skipped. Accessible viaisEnableIncrementalRefreshMV()andsetEnableIncrementalRefreshMv(boolean)inSessionVariable. - Scope: Session (per-connection)
- Default:
enable_insert_partial_updateβ
- Description: Whether to enable Partial Update for INSERT statements on Primary Key tables. When this item is set to
true(default), if an INSERT statement specifies only a subset of columns (fewer than the number of all non-generated columns in the table), the system performs a Partial Update to update only the specified columns while preserving existing values in other columns. When set tofalse, the system uses default values for unspecified columns instead of preserving existing values. This feature is particularly useful for updating specific columns in Primary Key tables without affecting other column values. - Default: true
- Introduced in: v3.3.20, v3.4.9, v3.5.8, v4.0.2
enable_insert_strictβ
- Description: Whether to enable strict mode while loading data using INSERT from files(). Valid values:
trueandfalse(Default). When strict mode is enabled, the system loads only qualified rows. It filters out unqualified rows and returns details about the unqualified rows. For more information, see Strict mode. In versions earlier than v3.4.0, whenenable_insert_strictis set totrue, the INSERT jobs fails when there is an unqualified rows. - Default: true
enable_lake_tablet_internal_parallelβ
- Description: Whether to enable Parallel Scan for Cloud-native tables in a shared-data cluster.
- Default: true
enable_lambda_pushdownβ
- Description: Session-scoped boolean toggle that controls predicate pushdown behavior in the optimizer. Specifically, the
PushDownPredicateProjectRuleconsults this flag: whentrue(default) the rule may push predicates throughProjectoperators even if those projects containLambdaFunctionOperatorexpressions; whenfalsethe rule inspects the project's expressions and aborts the pushdown if any lambda is present (the rule returns no transformation). This affects only the optimizer transformation phase (planning) and can be changed per session via theSessionVariablegetter/setter (getEnableLambdaPushDown/setEnableLambdaPushdown). - Scope: Session
- Default:
- Introduced in: v3.3.6, v3.4.0, v3.5.0
enable_large_in_predicateβ
- Scope: Session
- Description: When enabled, the parser will convert IN-lists whose literal count meets or exceeds
large_in_predicate_thresholdinto a specialLargeInPredicate(handled inAstBuilder). The optimizer ruleLargeInPredicateToJoinRulethen converts that predicate into aLEFT_SEMI_JOIN(for IN) orNULL_AWARE_LEFT_ANTI_JOIN(for NOT IN) against aRawValuesconstant table, reducing FE memory and planning cost for very large IN lists by avoiding one expression node per constant. The transformation has correctness restrictions (no OR compound predicates, only one large-IN per query); if these restrictions or other conditions cause the optimization to fail, the planner throwsLargeInPredicateExceptionand upper layers (viaStmtExecutor/ConnectProcessor) retry the query from the parser stage withenable_large_in_predicatedisabled so the query falls back to the traditional expression-based IN handling. Uselarge_in_predicate_thresholdto control the minimum literal count that triggers this behavior. - Default:
- Introduced in: -
max_unknown_string_meta_length (global)β
- Description: Fallback length for string columns in query result metadata when the max length is unknown. Clients that rely on the metadata may return empty values or truncation if the reported length is smaller than actual values. Valid range is
1to1048576. - Default: 64
- Data Type: int
- Introduced in: v3.5.16, v4.0.9, v4.1
enable_reduce_cast_varchar_length_inheritance (global)β
- Description: Whether to preserve the target
VARCHAR(N)length whenReduceCastRuleeliminates a same-typeVARCHAR -> VARCHARcast. Enable this variable to keep prepare and execute result-set metadata consistent for statements such asCAST(col AS VARCHAR(N)). - Default: false
enable_reduce_cast_varchar_expr_sync_type (global)β
- Description: Whether to synchronize the reused planner
Exprtype and origin type with the rewrittenVARCHAR(N)type afterReduceCastRuleeliminates a same-typeVARCHAR -> VARCHARcast. - Default: true
enable_load_profileβ
- Scope: Session
- Description: When enabled, the FE requests collection of the runtime profile for load jobs and the load coordinator will collect/export the profile after a load completes. For stream load, FE sets
TQueryOptions.enable_profile = trueand passesload_profile_collect_second(fromstream_load_profile_collect_threshold_second) to backends; the coordinator then conditionally calls profile collection (see StreamLoadTask.collectProfile()). The effective behavior is the logical OR of this session variable and the table-level propertyenable_load_profileon the destination table; collection is further gated byload_profile_collect_interval_second(FE-side sampling interval) to avoid frequent collection. The session flag is read viaSessionVariable.isEnableLoadProfile()and can be set per-connection withsetEnableLoadProfile(...). - Default:
enable_local_shuffle_aggβ
- Description: Controls whether the planner and cost model may produce a one-phase local aggregation plan that uses a local shuffle (Scan -> LocalShuffle -> OnePhaseAgg) instead of a two-phase/global-shuffle aggregation. When enabled (the default), the optimizer and cost model will:
- allow replacing a SHUFFLE exchange between Scan and Global Agg with a local shuffle + one-phase agg on single-backend-and-compute-node clusters (see
PruneShuffleDistributionNodeRuleandEnforceAndCostTask), - let the cost model ignore network cost for SHUFFLE in that single-node case to favor the one-phase plan (
CostModel). The replacement is only considered whenenable_pipeline_engineis enabled and the cluster is a single backend+compute node. The planner still rejects local-shuffle conversion in unsafe cases (e.g., DISTINCT aggregates, detected data skew, missing/unknown column statistics, multi-input operators like joins, or other semantic restrictions). Some code paths (INSERT/UPDATE/DELETE planners and MaterializedViewOptimizer) temporarily disable this session flag because non-query sinks or certain rewrites require per-driver scan assignment that local-shuffle cannot use.
- Scope: Session
- Default:
enable_materialized_view_agg_pushdown_rewriteβ
- Description: Whether to enable aggregation pushdown for materialized view query rewrite. If it is set to
true, aggregate functions will be pushed down to Scan Operator during query execution and rewritten by the materialized view before the Join Operator is executed. This will relieve the data expansion caused by Join and thereby improve the query performance. For detailed information about the scenarios and limitations of this feature, see Aggregation pushdown. - Default: false
enable_materialized_view_for_insertβ
- Description: Whether to allow StarRocks to rewrite queries in INSERT INTO SELECT statements.
- Default: false, which means Query Rewrite in such scenarios is disabled by default.
- Introduced in: v2.5.18, v3.0.9, v3.1.7, v3.2.2
enable_materialized_view_text_match_rewriteβ
- Description: Whether to enable text-based materialized view rewrite. When this item is set to true, the optimizer will compare the query with the existing materialized views. A query will be rewritten if the abstract syntax tree of the materialized view's definition matches that of the query or its sub-query.
- Default: true
- Introduced in: v3.2.5, v3.3.0
enable_materialized_view_union_rewriteβ
- Description: Whether to enable materialized view union rewrite. If this item is set to
true, the system seeks to compensate the predicates using UNION ALL when the predicates in the materialized view cannot satisfy the query's predicates. - Default: true
- Introduced in: v2.5.20, v3.1.9, v3.2.7, v3.3.0
enable_metadata_profileβ
- Description: Whether to enabled Profile for Iceberg Catalog metadata.
- Default: true
- Introduced in: v3.3.3
enable_multicolumn_global_runtime_filterβ
- If this feature is disabled, only Local RF works.
- If this feature is enabled, multi-column Global RF takes effect and carries
multi-columnin the partition by clause.
enable_mv_plannerβ
- Scope: Session
- Description: When enabled, activates the Materialized View (MV) planner mode for the current session. In this mode the optimizer:
- Uses MV-specific rule set via
context.getRuleSet().addRealtimeMVRules()instead of the regular join implementation rules (QueryOptimizer). - Allows stream implementation rules to apply (see
StreamImplementationRule.checkwhich returns true only when MV planner is on). - Alters scan/operator construction during logical plan transformation (e.g., RelationTransformer chooses
LogicalBinlogScanOperatorfor native tables/materialized views when MV planner is enabled). - Disables or bypasses some standard transformations (for example,
SplitMultiPhaseAggRule.checkreturns false when MV planner is on). Materialized view planning code (MaterializedViewAnalyzer) sets this flag around MV planning work (sets to true before planning and resets to false afterward), so it is primarily intended for MV plan generation and testing. Setting this session variable affects only the current sessionβs optimizer behavior.
- Default:
enable_optimize_skew_join_v1β
- Scope: Session
- Description: Controls which skew-join optimization strategy the optimizer uses. When set to
true, the optimizer enables the query-rewrite based skew join optimization: QueryOptimizer checkssessionVariable.isEnableOptimizerSkewJoinByQueryRewrite()after join-expression pushdown and, if enabled andenableOptimizerSkewJoinByBroadCastSkewValuesis disabled, invokesskewJoinOptimize(...)which appliesSkewJoinOptimizeRule. IfisEnableStatsToOptimizeSkewJoinis enabled,skewJoinOptimizefirst merges projects and computes statistics (Utils.calculateStatistics) before applying the rule. The session setters enforce mutual exclusivity betweenenableOptimizerSkewJoinByQueryRewriteandenableOptimizerSkewJoinByBroadCastSkewValues(setting one flips the other), so only one skew strategy is active at a time. - Default:
- Introduced in: -
enable_optimize_skew_join_v2β
- Description: When enabled, the optimizer uses the broadcasted-skew-values strategy (Skew Join v2) to handle skewed joins. In the optimizer this flag activates the SkewShuffleJoinEliminationRule during dynamic rewrite and disables the query-rewrite based skew-join path (skewJoinOptimize). The two skew-join strategies are mutually exclusive: enabling this variable sets
enable_optimize_skew_join_v1off and vice versa. This is a session-level variable intended to switch optimizer behavior for queries that benefit from using broadcasted skew statistics instead of query-rewrite transformations. Usage locations:QueryOptimizer.dynamicRewrite(...)and the main optimization flow inQueryOptimizerwhere skew-join optimization is applied. - Scope: Session
- Default:
- Introduced in: -
enable_parallel_mergeβ
- Description: Whether to enable parallel merge for sorting. When this feature is enabled, the merge phase of sorting will utilize multiple threads for merge operations.
- Default: true
enable_parquet_reader_bloom_filterβ
- Default: true
- Type: Boolean
- Unit: -
- Description: Whether to enable Bloom Filter optimization when reading Parquet files.
true(Default): Enable Bloom Filter optimization when reading Parquet files.false: Disable Bloom Filter optimization when reading Parquet files.
enable_parquet_reader_page_indexβ
- Default: true
- Type: Boolean
- Unit: -
- Description: Whether to enable Page Index optimization when reading Parquet files.
true(Default): Enable Page Index optimization when reading Parquet files.false: Disable Page Index optimization when reading Parquet files.
enable_partition_hash_joinβ
- Description: Whether to enable adaptive Partition Hash Join.
- Default: true
enable_per_bucket_optimizeβ
- Description: Whether to enable bucketed computation. When this feature is enabled, stage-one aggregation can be computed in bucketed order, reducing memory usage.
- Default: true
enable_phased_schedulerβ
- Description: Whether to enable multi-phased scheduling. When multi-phased scheduling is enabled, it will schedule fragments according to their dependencies. For example, the system will first schedule the fragment on the build side of a Shuffle Join, and then the fragment on the probe side (Note that, unlike stage-by-stage scheduling, phased scheduling is still under the MPP execution mode). Enabling multi-phased scheduling can significantly reduce memory usage for a large number of UNION ALL queries.
- Default: false
enable_pipeline_engineβ
- Description: Specifies whether to enable the pipeline execution engine.
trueindicates enabled andfalseindicates the opposite. Default value:true. - Default: true
enable_plan_advisorβ
- Description: Whether to enable Query Feedback feature for slow queries and manually marked queries.
- Default: true
enable_predicate_reorderβ
- Scope: Session
- Description: When enabled, the optimizer applies the Predicate Reorder rule to AND (conjunctive) predicates during logical/physical plan rewrite. The rule extracts conjuncts via
Utils.extractConjuncts, estimates each conjunct's selectivity withDefaultPredicateSelectivityEstimator, and reorders the conjuncts in ascending order of estimated selectivity (less restrictive first) to form a newCompoundPredicateOperator(AND). The rule only runs when the operator has aCompoundPredicateOperatorwith more than one conjunct. Statistics are gathered from childOptExpressionstatistics when available; forPhysicalOlapScanOperatorit will fetch column statistics fromGlobalStateMgr.getCurrentState().getStatisticStorage(). If child statistics are missing and the scan is not an OLAP scan, the rule skips reordering. The session variable is exposed viaSessionVariable.isEnablePredicateReorder(), withenablePredicateReorder()anddisablePredicateReorder()helper methods. - Default: false
enable_profileβ
Description: Specifies whether to send the profile of a query for analysis. The default value is
false, which means no profile is required.By default, a profile is sent to the FE only when a query error occurs in the BE. Profile sending causes network overhead and therefore affects high concurrency.
If you need to analyze the profile of a query, you can set this variable to
true. After the query is completed, the profile can be viewed on the web page of the currently connected FE (address:fe_host:fe_http_port/query). This page displays the profiles of the latest 100 queries withenable_profileturned on. -
Default: false
enable_query_cacheβ
- Description: Specifies whether to enable the Query Cache feature. Valid values: true and false.
truespecifies to enable this feature, andfalsespecifies to disable this feature. When this feature is enabled, it works only for queries that meet the conditions specified in the application scenarios of Query Cache. - Default: false
enable_query_dumpβ
- Description: Controls per-session query dumping. When this variable is set to true and HTTP Query Dump mode is not active, the server will collect and persist the session's Dump informatation. For non-HTTP queries, the system will serialize the session Dump information and write it to the Query Dump Log when an exception occurs. For HTTP-triggered dumps, the system uses a separate path (to add exception stack traces into the connection's Dump information). Use this variable to opt a session into FE-side query dump collection for post-mortem analysis and debugging; it is evaluated at runtime per session and does not affect global behavior.
- Default: false
enable_query_queue_load (global)β
- Description: Boolean value to enable query queues for loading tasks.
- Default: false
enable_query_queue_select (global)β
- Description: Whether to enable query queues for SELECT queries.
- Default: false
enable_query_queue_statistic (global)β
- Description: Whether to enable query queues for statistics queries.
- Default: false
enable_query_tablet_affinityβ
Description: Boolean value to control whether to direct multiple queries against the same tablet to a fixed replica.
However, if there are some hotspot tablets, this feature may degrade the query performance because it directs the queries to the same BE, making it unable to fully use the resources of multiple BEs in high concurrency scenarios.
Default: false, which means the system selects a replica for each query.
Introduced in: v2.5.6, v3.0.8, v3.1.4, and v3.2.0.
enable_query_trigger_analyzeβ
- Default: true
- Type: Boolean
- Description: Whether to enable query-trigger ANALYZE tasks on tables under external catalogs.
enable_rbo_table_pruneβ
- Description: When enabled, the optimizer applies Rule-Based (RBO) table pruning for cardinality-preserving joins in the current session. The optimizer runs a sequence of rewrite and pruning steps (partition pruning, project merge/separate,
UniquenessBasedTablePruneRule, join reorder, andRboTablePruneRule) to remove unnecessary table scan alternatives and reduce scanned partitions/rows in joins. Enabling this option also disables join-equivalence derivation (context.setEnableJoinEquivalenceDerive(false)) while logical rule rewrite is running to avoid conflicting transformations. The pruning flow may additionally runPrimaryKeyUpdateTableRulefor update statements ifenable_table_prune_on_updateis set. The rule is only executed when a query contains prunable joins (checked viaUtils.hasPrunableJoin(tree)). - Scope: Session
- Default:
enable_rewrite_groupingsets_to_union_allβ
- Scope: Session
- Description: When enabled, the optimizer applies the RewriteGroupingSetsByCTERule to transform SQL GROUPING SETS (including ROLLUP and CUBE semantics) into equivalent plans expressed as multiple aggregation branches combined with UNION ALL (implemented via CTEs). The system will conditionally run the iterative rewrite pass. This rewrite can improve compatibility with existing aggregation planning rules and enable further rule-based optimizations, but it typically expands the plan into multiple aggregation/union branches which may increase intermediate rows, memory usage, and planning time. If
cbo_push_down_grouping_setis also set totrue, the optimizer may additionally attempt push-down of grouping-set aggregates after or instead of this rewrite. - Default:
enable_runtime_adaptive_dopβ
- Scope: Session
- Description: When enabled for a session, the planner and fragment builder will mark pipeline-capable fragments that support runtime adaptive DOP to use adaptive degree-of-parallelism at runtime. This option only takes effect when
enable_pipeline_engineis true. Enabling it causes fragments to callenableAdaptiveDop()during plan construction, and has runtime implications: join probes may wait for all build phases to complete (which conflicts withgroup_executionbehavior), and enabling runtime adaptive DOP will disable pipeline-level multi-partitioned runtime filters (the setter clearsenablePipelineLevelMultiPartitionedRf). The flag is recorded in the query profile and can be toggled per-session. - Default:
false - Data type: boolean
enable_scan_datacacheβ
- Description: Specifies whether to enable the Data Cache feature. After this feature is enabled, StarRocks caches hot data read from external storage systems into blocks, which accelerates queries and analysis. For more information, see Data Cache. In versions prior to 3.2, this variable was named as
enable_scan_block_cache. - Default: true
enable_shared_scanβ
- Scope: Session
- Description: Session-level boolean flag intended to request shared scan execution for pipeline queries. When pipeline execution is enabled, the FE will propagate this setting into the fragment execution parameters (
TExecPlanFragmentParams.enable_shared_scan) so the BE can perform shared scanning (see.../TFragmentInstanceFactory.java:153-159). However, the FE currently does not honor user changes:SessionVariable.isEnableSharedScan()always returnsfalse(see.../SessionVariable.java:4176-4180) and the feature has been disabled in FE since later versions due to incompatibility with event-based scheduling. As a result, setting this variable in a session has no effect in current releases. - Default:
enable_short_circuitβ
- Description: Whether to enable short circuiting for queries. Default:
false. If it is set totrue, when the query meets the criteria (to evaluate whether the query is a point query): the conditional columns in the WHERE clause include all primary key columns, and the operators in the WHERE clause are=orIN, the query takes the short circuit. - Default: false
enable_sort_aggregateβ
- Description: Specifies whether to enable sorted streaming.
trueindicates sorted streaming is enabled to sort data in data streams. - Default: false
enable_spillβ
- Description: Whether to enable intermediate result spilling. Default:
false. If it is set totrue, StarRocks spills the intermediate results to disk to reduce the memory usage when processing aggregate, sort, or join operators in queries. - Default: false
- Introduced in: v3.0
enable_spill_to_remote_storageβ
- Description: Whether to enable intermediate result spilling to object storage. If it is set to
true, StarRocks spills the intermediate results to the storage volume specified inspill_storage_volumeafter the capacity limit of the local disk is reached. For more information, see Spill to object storage. - Default: false
- Introduced in: v3.3.0
enable_split_topn_aggβ
- Description: Controls whether the optimizer may apply the SplitTopNAggregate transformation (implemented in
SplitTopNAggregateRule.java). When enabled, the optimizer can rewrite a plan that has a TopN on top of an aggregation over an OLAP scan into a plan that:- computes a restricted TopN-aggregation on a right-side partial scan (push-down),
- joins the TopN result back to the full scan,
- and finalizes aggregation on the join result. This rewrite is intended to reduce work when TopN orders by aggregated columns and the limit is small. The rule is gated by several precise checks:
- TopN limit is set and less than or equal to
split_topn_agg_limit(sessionsplitTopNAggLimit, default 10000). - scan/agg projections are identity (no column remapping).
- statistics/row-count heuristics (skip when outputRowCount < limit * 10 and stats are reliable, unless running unit tests).
- duplicated columns to be read twice β€ 3.
- duplicated columns are not long strings or complex types (string with averageRowSize β₯ 5 or missing stats is treated as long).
- predicate complexity limits (β€ 2 conjuncts and β€ 2 disjuncts).
- only a subset (not zero or all) of aggregations are referenced by ORDER BY.
- Scope: Session
- Default:
- Introduced in: -
enable_split_topn_agg_limitβ
- Description: Session-level threshold (row count) that controls whether the SplitTopN aggregate optimization may be applied. When
enable_split_topn_aggis on, the optimizer's SplitTopNAggregateRule will skip the split transformation if the TopN operator's LIMIT is equal to the default unlimited value or greater than this threshold. This variable only governs the numeric cutoff (number of rows); the rule still enforces other correctness and cost checks (projections, predicates, column/type constraints and scan statistics) before applying the transformation. - Scope: Session
- Default:
10000 - Data Type: long
- Introduced in: -
enable_spm_rewriteβ
- Description: Whether to enable SQL Plan Manager (SPM) query rewrite. When enabled, StarRocks automatically rewrites queries to use bound query plans, improving query performance and stability.
- Default: false
enable_strict_order_byβ
- Description: Used to check whether the column name referenced in ORDER BY is ambiguous. When this variable is set to the default value
TRUE, an error is reported for such a query pattern: Duplicate alias is used in different expressions of the query and this alias is also a sorting field in ORDER BY, for example,select distinct t1.* from tbl1 t1 order by t1.k1;. The logic is the same as that in v2.3 and earlier. When this variable is set toFALSE, a loose deduplication mechanism is used, which processes such queries as valid SQL queries. - Default: true
- Introduced in: v2.5.18 and v3.1.7
enable_sync_materialized_view_rewriteβ
- Description: Whether to enable query rewrite based on synchronous materialized views.
- Default: true
- Introduced in: v3.1.11, v3.2.5
enable_table_prune_on_updateβ
- Description: Session-level boolean that controls whether the optimizer applies primary-key-specific table pruning rules for UPDATE statements. When enabled, QueryOptimizer (during the pruneTables stage) invokes
PrimaryKeyUpdateTableRuleto rewrite/prune update plans β potentially improving pruning for primary-key update patterns. This flag is only effective when rule-based/CBO table pruning is active (seeenable_rbo_table_prune). It is disabled by default because the transformation can change data-layout/plan shape (e.g., bucket-shuffle layout for OlapTableSink) and may cause correctness or performance regressions for concurrent updates. - Default:
- Introduced in: v3.2.4
enable_tablet_internal_parallelβ
- Description: Whether to enable adaptive parallel scanning of tablets. After this feature is enabled, multiple threads can be used to scan one tablet by segment, increasing the scan concurrency.
- Default: true
- Introduced in: v2.3
enable_tablet_pre_splitβ
- Description: Per-session opt-out for Sample-Based Tablet Pre-Split. Defaults to
trueso the FE Config gates (enable_tablet_pre_split_for_*) remain the primary on/off switch. Set this tofalsefor a session whose load you want to leave undisturbed. Both the matching Config flag and this session variable must betruefor pre-split to run. - Default: true
enable_topn_runtime_filterβ
- Description: Whether to enable TopN Runtime Filter. If this feature is enabled, a runtime filter will be dynamically constructed for ORDER BY LIMIT queries and pushed down to the scan for filtering.
- Default: true
enable_ukfk_join_reorderβ
- Scope: Session
- Description: When enabled, the optimizer collects Unique Key (UK) / Foreign Key (FK) column constraints for the two join sides and uses that information to bias join reordering. If a join has an intact UK constraint, the optimizer may choose the FK table as the right child (probe/input) instead of using plain row-count comparison. The decision uses the helper allowFKAsRightTable(), which:
- rejects reordering when the FK side is ordered by the FK column (
fkConstraint.isOrderByFK), - computes normalized row counts by scaling row counts with summed column type sizes,
- computes a scale ratio = fkNormalizedRows / max(1, ukNormalizedRows), and
- allows the FK as right table only when the scale ratio and FK rows are below session thresholds (
max_ukfk_join_reorder_scale_ratioandmax_ukfk_join_reorder_fk_rows). If UK/FK conditions are not met, join ordering falls back to the default smaller-table-as-right-child heuristic (rowCount comparison). The variable is accessed via SessionVariable getters/setters and used in the JoinOrder optimizer rule.
- Default:
enable_ukfk_optβ
- Description: Enables optimizer support for Unique-Key / Foreign-Key (UK/FK) based transformations and statistics enhancements. When set, the optimizer runs
UKFKConstraintsCollectorto collect unique and foreign-key constraints bottomβup and attach them to plan nodes (OptExpressions). The collected constraints are consumed by transformation rules such asPruneUKFKJoinRule(which can prune the UK-side of joins, rewrite predicates from UK to FK columns and add IS NULL checks for outer-join cases) andPruneUKFKGroupByKeysRule(which can remove redundant GROUP BY keys derived from UK/FK relationships). The collected UK/FK information is also used inStatisticsCalculatorto produce tighter join cardinality estimates for UKβFK joins and may replace default estimates when more precise. Default is conservative (false) because these optimizations rely on declared schema constraints and can change plan shape and predicate placement. - Default:
false - Scope: Session
enable_view_based_mv_rewriteβ
- Description: Whether to enable query rewrite for logical view-based materialized views. If this item is set to
true, the logical view is used as a unified node to rewrite the queries against itself for better performance. If this item is set tofalse, the system transcribes the queries against logical views into queries against physical tables or materialized views and then rewrites them. - Default: false
- Introduced in: v3.1.9, v3.2.5, v3.3.0
enable_wait_dependent_eventβ
- Description: Whether Pipeline waits for a dependent operator to finish execution before continuing within the same fragment. For example, in a left join query, when this feature is enabled, the probe-side operator waits for the build-side operator to finish before it starts executing. Enabling this feature can reduce memory usage, but may increase the query latency. However, for queries reused in CTE, enabling this feature may increase memory usage.
- Default: false
enable_write_hive_external_tableβ
- Description: Whether to allow for sinking data to external tables of Hive.
- Default: false
event_schedulerβ
force_schedule_local (Session)β
- Scope: Session
- Description: When enabled, the query scheduler prefers assigning HDFS/file scan ranges to coβlocated (local) compute backends that host the data blocks.
HDFSBackendSelectorreceives this flag from the session and calls its computeForceScheduleLocalAssignment(...) path to: 1) select backends whose hostnames match scan-range locations, 2) choose among those local backends using reBalanceScanRangeForComputeNode(...) (which considers per-node assigned bytes and a max imbalance ratio), and 3) return remaining ranges for remote assignment via consistent hashing.HiveConnectorScanRangeSourcealso reads this session variable and, when set, emits block-level scan ranges (one per block) to enable local placement. Use this to improve data locality and reduce network I/O. Note it can increase skew (assignment imbalance) and may cause more rebalancing in heavy-locality scenarios. - Default:
- Introduced in: v3.2.0
forward_to_leaderβ
SHOW FRONTENDS: Forwarding to the leader FE allows users to view the last heartbeat message.
SHOW BACKENDS: Forwarding to the leader FE allows users to view the boot time, last heartbeat information, and disk capacity information.
SHOW BROKER: Forwarding to the leader FE allows users to view the boot time and last heartbeat information.
SHOW TABLET
ADMIN SHOW REPLICA STATUS: Forwarding to the leader FE allows users to view the tablet information stored in the metadata of the leader FE. Normally, the tablet information should be the same in the metadata of different FEs. If an error occurs, you can use this method to compare the metadata of the current FE and the leader FE.
Show PROC: Forwarding to the leader FE allows users to view the PROC information stored in the metadata. This is mainly used for metadata comparison.
group_concat_max_lenβ
- Description: The maximum length of string returned by the group_concat function.
- Default: 1024
- Min value: 4
- Unit: Characters
- Data type: Long
group_execution_max_groupsβ
- Description: Maximum number of groups allowed for Group Execution. It is used to limit the granularity of splitting, preventing excessive scheduling overhead caused by an excessive number of groups.
- Default: 128
group_execution_min_scan_rowsβ
- Description: Minimum number of rows processed per group for Group Execution.
- Default: 5000000
hash_join_push_down_right_tableβ
- Description: Used to control whether the data of the left table can be filtered by using the filter condition against the right table in the Join query. If so, it can reduce the amount of data that needs to be processed during the query.
Default:
trueindicates the operation is allowed and the system decides whether the left table can be filtered.falseindicates the operation is disabled. The default value istrue.
historical_nodes_min_update_intervalβ
- Description: The minimum interval between two updates of historical node records. If the nodes of a cluster change frequently in a short period of time (that is, less than the value set in this variable), some intermediate states will not be recorded as valid historical node snapshots. The historical nodes are the main basis for the Cache Sharing feature to choose the right cache nodes during cluster scaling.
- Default: 600
- Unit: Seconds
init_connect (global)β
innodb_read_onlyβ
- Description: Session-level flag (MySQL-compatible) that indicates the session's InnoDB read-only mode. The variable is declared and stored on the session as the Java field
innodbReadOnlyinSessionVariable.javaand is accessible viaisInnodbReadOnly()andsetInnodbReadOnly(boolean). The SessionVariable class only holds the flag; any enforcement (preventing write/DDL to InnoDB tables or altering transaction behavior) must be implemented by the transaction/storage/authorization layers which should read this session flag. Use this variable to convey client intent for read-only behavior within the current session for components that respect it. - Scope: Session
- Default:
true - Data Type: boolean
insert_max_filter_ratioβ
- Description: The maximum error tolerance of INSERT from files(). It's the maximum ratio of data records that can be filtered out due to inadequate data quality. When the ratio of unqualified data records reaches this threshold, the job fails. Range: [0, 1].
- Default: 0
- Introduced in: v3.4.0
insert_timeoutβ
- Description: The timeout duration of the INSERT job. Unit: Seconds. From v3.4.0 onwards,
insert_timeoutapplies to operations involved INSERT (for example, UPDATE, DELETE, CTAS, materialized view refresh, statistics collection, and PIPE), replacingquery_timeout. - Default: 14400
interactive_timeoutβ
- Description: The number of concurrent I/O tasks that can be issued by a scan operator. Increase this value if you want to access remote storage systems such as HDFS or S3 but the latency is high. However, a larger value causes more memory consumption.
- Default: 4
- Data type: Int
jit_levelβ
- Description: The level at which JIT compilation for expressions is enabled. Valid values:
1: The system adaptively enables JIT compilation for compilable expressions.-1: JIT compilation is enabled for all compilable, non-constant expressions.0: JIT compilation is disabled. You can disable it manually if any error is returned for this feature.
- Default: 1
- Data type: Int
- Introduced in: -
join_late_materializationβ
- Scope: Session
- Description: Controls whether the planner enables "late materialization" on join operators. When set to
true, PlanFragmentBuilder reads the session flag and callsjoinNode.setEnableLateMaterialization(...)so join execution can defer full row/payload materialization until after join/key-based filtering. This reduces memory usage and I/O for joins with large payload columns or highly selective join predicates by carrying only join keys through the join and materializing payloads for matched rows. The flag is defined inSessionVariable.javaasJOIN_LATE_MATERIALIZATIONand defaults tofalse. Enabling this may interact with column-trimming and scan-stage pruning optimizations (for exampleenable_filter_unused_columns_in_scan_stage) and can change join runtime behavior; test queries for correctness and performance before enabling broadly. - Default:
- Introduced in: v3.3.0, v3.4.0, v3.5.0
lake_bucket_assign_modeβ
- Description: The bucket assignment mode for queries against tables in data lakes. This variable controls how buckets are distributed among worker nodes when bucket-aware execution takes effect during query execution. Valid values:
balance: Distributes buckets evenly across worker nodes to achieve balanced workload and better performance.elastic: Uses consistent hashing to assign buckets to worker nodes, which can provide better load distribution in elastic environments.
- Default: balance
- Data type: String
language (global)β
large_in_predicate_thresholdβ
- Scope: Session
- Description: Threshold (number of constants) at which the planner switches a regular IN-list predicate into the compact LargeInPredicate representation to avoid building very large ASTs and heavy FE analysis/planning overhead. When
enable_large_in_predicateis true and an IN-list (string or integer) contains >= this many literals, the parser (AstBuilder) creates a LargeInPredicate containing the raw text and a compact value list (and keeps only a minimal representative Expr in the AST). For integer lists the parser additionally verifies all literals can be parsed as integral values and will fall back to a normal InPredicate if parsing fails. LargeInPredicate is later transformed into a left semi/anti join for execution, improving parse/analyze/deploy performance for queries with very large constant IN lists. The variable is exposed as a session-levelVariableMgr.VarAttrand can be get/set per session. - Default:
100000 - Data Type: int
- Introduced in: -
license (global)β
- Description: Displays the license of StarRocks.
- Default: Apache License 2.0
load_mem_limitβ
log_rejected_record_num (v3.1 and later)β
- The value
0specifies that data rows that are filtered out will not be logged. - The value
-1specifies that all data rows that are filtered out will be logged. - A non-zero positive integer such as
nspecifies that up tondata rows that are filtered out can be logged on each BE.
low_cardinality_optimize_on_lakeβ
- Default: true
- Type: Boolean
- Unit: -
- Description: Whether to enable low cardinality optimization on data lake queries. Valid values:
true(Default): Enable low cardinality optimization on data lake queries.false: Disable low cardinality optimization on data lake queries.
- Introduced in: v3.5.0
low_cardinality_optimize_v2β
- Scope: Session
- Description: Session-level boolean that selects which low-cardinality optimization rewrite strategy the optimizer applies. When
truethe optimizer will attempt the V2 rewrite strategy implemented byLowCardinalityRewriteRule(usesDecodeCollector/DecodeRewriterto encode/decode low-cardinality VARCHAR columns). Whenfalsethe optimizer falls back to the legacy rewrite strategy implemented byAddDecodeNodeForDictStringRule. Execution of either rewrite also requiresenableLowCardinalityOptimizeto be enabled; ifenableLowCardinalityOptimizeis disabled, no low-cardinality rewrite is performed. The variable is checked in optimizer tree-rewrite paths to choose the appropriate transformation. - Default:
lower_case_table_names (global)β
materialized_view_rewrite_mode (v3.2 and later)β
disable: Disable automatic query rewrite of asynchronous materialized views.default(Default value): Enable automatic query rewrite of asynchronous materialized views, and allow the optimizer to decide whether a query can be rewritten using the materialized view based on the cost. If the query cannot be rewritten, it directly scans the data in the base table.default_or_error: Enable automatic query rewrite of asynchronous materialized views, and allow the optimizer to decide whether a query can be rewritten using the materialized view based on the cost. If the query cannot be rewritten, an error is returned.force: Enable automatic query rewrite of asynchronous materialized views, and the optimizer prioritizes query rewrite using the materialized view. If the query cannot be rewritten, it directly scans the data in the base table.force_or_error: Enable automatic query rewrite of asynchronous materialized views, and the optimizer prioritizes query rewrite using the materialized view. If the query cannot be rewritten, an error is returned.
materialized_view_subquery_text_match_max_countβ
- Description: Specifies the maximum number of times that the system checks whether a query's sub-query matches the materialized views' definition.
- Default: 4
max_allowed_packetβ
- Description: Used for compatibility with the JDBC connection pool C3P0. This variable specifies the maximum size of packets that can be transmitted between the client and server.
- Default: 33554432 (32 MB). You can raise this value if the client reports "PacketTooBigException".
- Unit: Byte
- Data type: Int
max_parallel_scan_instance_numβ
- Scope: Session
- Description: Session-level integer that caps the number of parallel scan instances the planner will produce for scan operators (applied to OLAP/Lake scan nodes). The value is propagated into the scan node Thrift message (
TOlapScanNode.max_parallel_scan_instance_num) and is included in query/load runtime profiles. It is declared with@VariableMgr.VarAttrand can be read/set via the session variable APIs (getMaxParallelScanInstanceNum/setMaxParallelScanInstanceNum). Use this to limit scan parallelism per session for resource control or debugging. When left at the default-1, the planner/system default (resource- or configuration-derived) parallelism is used. - Default:
-1 - Data Type: int
max_pipeline_dopβ
- Scope: Session
- Description: The per-session upper bound for the pipeline engine's degree-of-parallelism (DOP). Behavior:
- Applies only when
enable_pipeline_engineis enabled andpipeline_dopis not explicitly set (greater than 0). Ifpipeline_dopgreater than 0 this variable is ignored andpipeline_dopis used directly. - When
pipeline_dopless than or equal to 0 (adaptive/default mode), the effective DOP for execution is computed as min(max_pipeline_dop, the backend default DOP returned by BackendResourceStat). For pipeline sinks the same logic uses the sink default DOP. - If
max_pipeline_dopless than or equal to 0 no additional cap is applied and the backend default DOP is used. - Purpose: avoid negative overhead from scheduling on machines with very large core counts by capping automatically computed parallelism.
- Applies only when
- Default:
64 - Data Type: int
max_pushdown_conditions_per_columnβ
- Description: The maximum number of predicates that can be pushed down for a column.
- Default: -1, indicating that the value in the
be.conffile is used. If this variable is set to a value greater than 0, the value inbe.confis ignored. - Data type: Int
max_scan_key_numβ
- Description: The maximum number of scan key segmented by each query.
metadata_collect_query_timeoutβ
- Description: The timeout duration for Iceberg Catalog metadata collection queries.
- Unit: Second
- Default: 60
nested_mv_rewrite_max_levelβ
- Description: The maximum levels of nested materialized views that can be used for query rewrite.
- Value range: [1, +β). The value of
1indicates that only materialized views created on base tables can be used for query rewrite. - Default: 3
- Data type: Int
net_buffer_lengthβ
net_read_timeoutβ
net_write_timeoutβ
- Scope: Session
- Description: Controls how the new planner selects aggregation phase decomposition. Valid integer values (0β4):
0(AUTO) β allow the optimizer to choose the aggregation stage selection. When0is set, cost-based multi-stage decisions can be enabled viaenable_cost_based_multi_stage_agg.1(ONE_STAGE) β force a single-stage aggregate.2(TWO_STAGE) β force a two-stage aggregate.3(THREE_STAGE) β force a three-stage aggregate (only producible for single-column DISTINCT scenarios).4(FOUR_STAGE) β force a four-stage aggregate (only producible for single-column DISTINCT scenarios). Setting a forced stage overrides automatic selection logic used by optimizer rules (for example, SplitMultiPhaseAggRule and related cost checks). When0is set, the planner may still be constrained byenable_cost_based_multi_stage_agg. The variable is consulted in cost enforcement (EnforceAndCostTask), aggregation-splitting rules, and plan-fragment construction to influence exchange/partitioning and pruning decisions.
- Default:
0 - Data Type: int
new_planner_optimize_timeoutβ
- Description: The timeout duration of the query optimizer. When the optimizer times out, an error is returned and the query is stopped, which affects the query performance. You can set this variable to a larger value based on your query or contact StarRocks technical support for troubleshooting. A timeout often occurs when a query has too many joins.
- Default: 3000
- Unit: ms
optimizer_materialized_view_timelimitβ
- Description: Specifies the maximum time that one materialized view rewrite rule can consume. When the threshold is reached, this rule will not be used for query rewrite.
- Default: 1000
- Unit: ms
orc_use_column_namesβ
- Description: Used to specify how columns are matched when StarRocks reads ORC files from Hive. The default value is
false, which means columns in ORC files are read based on their ordinal positions in the Hive table definition. If this variable is set totrue, columns are read based on their names. - Default: false
- Introduced in: v3.1.10
parallel_exchange_instance_numβ
parallel_fragment_exec_instance_numβ
parallel_merge_late_materialization_modeβ
- Description: The late materialization mode of parallel merge for sorting. Valid values:
AUTOALWAYSNEVER
- Default:
AUTO - Introduced in: v3.3
partial_update_modeβ
Description: Used to control the mode of partial updates. Valid values:
auto(default): The system automatically determines the mode of partial updates by analyzing the UPDATE statement and the columns involved.column: The column mode is used for the partial updates, which is particularly suitable for the partial updates which involve a small number of columns and a large number of rows.
Default: auto
Introduced in: v3.1
performance_schema (global)β
phased_scheduler_max_concurrencyβ
- Description: The concurrency for phased scheduler scheduling leaf node fragments. For example, the default value means that, in a large number of UNION ALL Scan queries, at most two scan fragments are allowed to be scheduled at the same time.
- Default: 2
pipeline_dopβ
Description: The parallelism of a pipeline instance, which is used to adjust the query concurrency. Default value: 0, indicating the system automatically adjusts the parallelism of each pipeline instance. This variable also controls the parallelism of loading jobs on OLAP tables. You can also set this variable to a value greater than 0. Generally, set the value to half the number of physical CPU cores. From v3.0 onwards, StarRocks adaptively adjusts this variable based on query parallelism.
Default: 0
Data type: Int
pipeline_profile_levelβ
Description: Controls the level of the query profile. A query profile often has five layers: Fragment, FragmentInstance, Pipeline, PipelineDriver, and Operator. Different levels provide different details of the profile:
- 0: StarRocks combines metrics of the profile and shows only a few core metrics.
- 1: default value. StarRocks simplifies the profile and combines metrics of the profile to reduce profile layers.
- 2: StarRocks retains all the layers of the profile. The profile size is large in this scenario, especially when the SQL query is complex. This value is not recommended.
Default: 1
Data type: Int
pipeline_sink_dopβ
- Description: The parallelism of sink for loading data into Iceberg tables and Hive tables, and unloading data using INSERT INTO FILES(). It is used to adjust the concurrency of these loading jobs. Default value: 0, indicating the system automatically adjusts the parallelism. You can also set this variable to a value greater than 0.
- Default: 0
- Data type: Int
plan_modeβ
- Description: The metadata retrieval strategy of Iceberg Catalog. For more information, see Iceberg Catalog metadata retrieval strategy. Valid values:
auto: The system will automatically select the retrieval plan.local: Use the local cache plan.distributed: Use the distributed plan.
- Default: auto
enable_iceberg_column_statisticsβ
- Description: Whether to obtain column statistics, such as
min,max,null count,row size, andndv(if a puffin file exists). When this item is set tofalse, only the row count information will be collected. - Default: false
populate_datacache_modeβ
- Description: Specifies the population behavior of Data Cache when reading data blocks from external storage systems. Valid values:
auto(default): the system automatically caches data selectively based on the population rule.always: Always cache the data.never: Never cache the data.
- Default: auto
query_cache_agg_cardinality_limitβ
- Description: The upper limit of cardinality for GROUP BY in Query Cache. Query Cache is not enabled if the rows generated by GROUP BY exceeds this value. Default value: 5000000. If
query_cache_entry_max_bytesorquery_cache_entry_max_rowsis set to 0, the Passthrough mode is used even when no computation results are generated from the involved tablets. - Default: 5000000
- Data type: Long
query_cache_entry_max_bytesβ
- Description: The threshold for triggering the Passthrough mode. When the number of bytes or rows from the computation results of a specific tablet accessed by a query exceeds the threshold specified by
query_cache_entry_max_bytesorquery_cache_entry_max_rows, the query is switched to Passthrough mode. - Valid values: 0 to 9223372036854775807
- Default: 4194304
- Unit: Byte
query_cache_entry_max_rowsβ
- Description: The upper limit of rows that can be cached. See the description in
query_cache_entry_max_bytes. Default value: . - Default: 409600
query_cache_size (global)β
query_cache_typeβ
query_delivery_timeoutβ
- Scope: Session
- Description: Timeout (in seconds) for phase 1 of query execution β the delivery of all plan fragment instances from the coordinator (FE) to backend executors (BEs). StarRocks executes queries in two phases: (1) deliver fragments to BEs, and (2) pull results after fragments are prepared.
query_delivery_timeoutcontrols how long the coordinator waits for fragment delivery to complete before timing out. When building the query options sent to the backend, the value is assigned to thequery_delivery_timeoutfield (subject to an internal cap to avoid integer overflow). IfenablePhasedScheduleris enabled, the system uses thequery_timeoutvalue instead for delivery timeout. - Default:
300 - Data Type: int (seconds)
query_mem_limitβ
- Description: Used to set the memory limit of a query on each BE node. The default value is 0, which means no limit for it. This item takes effect only after Pipeline Engine is enabled. When the
Memory Exceed Limiterror happens, you could try to increase this variable. Setting it to0indicates no limit is imposed. - Default: 0
- Unit: Byte
query_queue_concurrency_limit (global)β
- Description: The upper limit of concurrent queries on a BE. It takes effect only after being set greater than
0. Setting it to0indicates no limit is imposed. - Default: 0
- Data type: Int
query_queue_cpu_used_permille_limit (global)β
- Description: The upper limit of CPU usage permille (CPU usage * 1000) on a BE. It takes effect only after being set greater than
0. Setting it to0indicates no limit is imposed. - Value range: [0, 1000]
- Default:
0
query_queue_max_queued_queries (global)β
- Description: The upper limit of queries in a queue. When this threshold is reached, incoming queries are rejected. It takes effect only after being set greater than
1024.
query_queue_mem_used_pct_limit (global)β
- Description: The upper limit of memory usage percentage on a BE. It takes effect only after being set greater than
0. Setting it to0indicates no limit is imposed. - Value range: [0, 1]
- Default: 0
query_queue_pending_timeout_second (global)β
- Description: The maximum timeout of a pending query in a queue. When this threshold is reached, the corresponding query is rejected.
- Default: 300
- Unit: Second
query_timeoutβ
- Description: Used to set the query timeout in "seconds". This variable will act on all query statements in the current connection. The default value is 300 seconds. From v3.4.0 onwards,
query_timeoutdoes not apply to operations involved INSERT (for example, UPDATE, DELETE, CTAS, materialized view refresh, statistics collection, and PIPE). - Value range: [1, 259200]
- Default: 300
- Data type: Int
- Unit: Second
range_pruner_max_predicateβ
- Description: The maximum number of IN predicates that can be used for Range partition pruning. Default value: 100. A value larger than 100 may cause the system to scan all tablets, which compromises the query performance.
- Default: 100
resource_groupβ
- Description: The specified resource group of this session
- Default: ""
- Data Type: String
- Introduced in: 3.2.0
runtime_filter_on_exchange_nodeβ
Description: Whether to place GRF on Exchange Node after GRF is pushed down across the Exchange operator to a lower-level operator. The default value is
false, which means GRF will not be placed on Exchange Node after it is pushed down across the Exchange operator to a lower-level operator. This prevents repetitive use of GRF and reduces the computation time.However, GRF delivery is a "try-best" process. If the lower-level operator fails to receive the GRF but the GRF is not placed on Exchange Node, data cannot be filtered, which compromises filter performance.
truemeans GRF will still be placed on Exchange Node even after it is pushed down across the Exchange operator to a lower-level operator. -
Default: false
runtime_join_filter_push_down_limitβ
- Description: The maximum number of rows allowed for the Hash table based on which Bloom filter Local RF is generated. Local RF will not be generated if this value is exceeded. This variable prevents the generation of an excessively long Local RF.
- Default: 1024000
- Data type: Int
runtime_profile_report_intervalβ
- Description: The time interval at which runtime profiles are reported.
- Default: 10
- Unit: Second
- Data type: Int
- Introduced in: v3.1.0
scan_olap_partition_num_limitβ
- Description: The number of partitions allowed to be scanned for a single table in the execution plan.
- Default: 0 (No limit)
- Introduced in: v3.3.9
skip_local_disk_cacheβ
- Description: Session flag that instructs the FE, when building scan ranges, to mark each tablet's internal scan range with
skip_disk_cache. When set totrue,OlapScanNode.addScanRangeLocations()setsinternalRange.setSkip_disk_cache(true)on the createdTInternalScanRangeobjects so downstream BE scan nodes are told to bypass the local disk cache for that scan. It is applied per-session and is evaluated at plan/scan-range construction time. Use this together withskip_page_cache(to control page cache skipping) and data-cache related variables (enable_scan_datacache/enable_populate_datacache) as appropriate. - Scope: Session
- Default:
false - Data Type: boolean
- Introduced in: v3.3.9, v3.4.0, v3.5.0
skip_page_cacheβ
- Scope: Session
- Description: Session-level boolean flag that instructs the planner/frontend to mark scan ranges so backends should bypass the page cache when reading data. When enabled,
OlapScanNode.addScanRangeLocationssetsTInternalScanRange.skip_page_cachefor each scan range sent to the backend, causing storage reads to skip the OS/page caching layer. Typical use cases: large one-time scans where avoiding page-cache pollution is desired or when a user prefers direct I/O semantics. Do not confuse withskip_local_disk_cache, which controls the storage-layer data cache;fill_data_cachecan also influence caching behavior. - Default:
spill_encode_levelβ
- Scope: Session
- Description: Controls the encoding/compression behaviour applied to operator spill files. The integer is a bit-flag level whose meanings mirror
transmission_encode_level:- bit 1 (value
1) β enable adaptive encoding; - bit 2 (value
2) β encode integer-like columns with streamvbyte; - bit 4 (value
4) β compress binary/string columns with LZ4. Example semantics from the relatedtransmission_encode_levelcomment:7enables adaptive encoding for numbers and strings;6forces encoding of numbers and strings. Changing this value adjusts CPU vs. disk I/O trade-offs for spills (higher encoding levels increase CPU work but reduce spill size / I/O). Implemented as the session variable annotatedSPILL_ENCODE_LEVELinSessionVariable.java(gettergetSpillEncodeLevel()), and documented adjacent to other spill tunables such asspill_mem_table_size.
- bit 1 (value
- Default:
7 - Data Type: int
spill_mode (3.0 and later)β
auto: Spilling is automatically triggered when the memory usage threshold is reached.force: StarRocks forcibly executes spilling for all relevant operators, regardless of memory usage.
spill_partitionwise_aggβ
- Description: Session-level flag that enables partition-wise aggregation behavior when spill is used for aggregation operators. When
spill_partitionwise_aggis true (andenable_spillis enabled), the execution engine will partition spilled aggregation data and perform per-partition spill/merge processing. The flag is propagated to execution viaTSpillOptions.setSpill_partitionwise_agg. Related session settings that affect its behavior arespill_partitionwise_agg_partition_num(number of partitions created) andspill_partitionwise_agg_skew_elimination(skew handling). This option reduces peak memory usage for large-group aggregations by splitting work across partitions during spill, but may increase I/O and merge overhead. - Scope: Session
- Default:
- Introduced in: v3.5.2
spill_revocable_max_bytesβ
- Scope: Session
- Description: Experimental per-session threshold (in bytes) for operator revocable memory. If an operator's revocable memory exceeds this value, the operator will initiate spilling to disk "as soon as possible" to free revocable memory. Use this to tune aggressive spilling for memoryβintensive operators; the value is interpreted in bytes.
- Default:
0 - Data Type: long
spill_storage_volumeβ
- Description: The storage volume with which you want to store the intermediate results of queries that triggered spilling. For more information, see Spill to object storage.
- Default: Empty string
sql_dialectβ
Description: The SQL dialect that is used. For example, you can run the
set sql_dialect = 'trino';command to set the SQL dialect to Trino, so you can use Trino-specific SQL syntax and functions in your queries.NOTICE
Data type: StarRocks
Introduced in: v3.0
sql_modeβ
PIPES_AS_CONCAT: The pipe symbol|is used to concatenate strings, for example,select 'hello ' || 'world'.ONLY_FULL_GROUP_BY(Default): The SELECT LIST can only contain GROUP BY columns or aggregate functions.ALLOW_THROW_EXCEPTION: returns an error instead of NULL when type conversion fails.FORBID_INVALID_DATE: prohibits invalid dates.MODE_DOUBLE_LITERAL: interprets floating-point types as DOUBLE rather than DECIMAL.SORT_NULLS_LAST: places NULL values at the end after sorting.ERROR_IF_OVERFLOW: returns an error instead of NULL in the case of arithmetic overflow. Currently, only the DECIMAL data type supports this option.GROUP_CONCAT_LEGACY: uses thegroup_concatsyntax of v2.5 and earlier. This option is supported from v3.0.9 and v3.1.6.STRUCT_CAST_BY_NAME: enables name-based field matching when casting between STRUCT types, rather than the default position-based matching. When this mode is enabled, fields in the source struct are matched to fields in the target struct by field name (case-insensitively), regardless of the order in which they are declared. Fields present in the source but absent in the target are ignored; fields present in the target but absent in the source are filled with NULL. This mode affects both the FE type resolution (common supertype computation for UNION ALL and castability checks) and the BE cast evaluation (runtime field reordering in CastStructExpr). This is particularly useful when performing UNION ALL on STRUCT columns whose fields are defined in different orders across branches.
sql_safe_updatesβ
sql_select_limitβ
- Description: Used to limit the maximum number of rows returned by a query, which can prevent issues such as insufficient memory or network congestion caused by the query returning too much data.
- Default: Unlimited
- Data type: Long
storage_engineβ
- olap (default): StarRocks system-owned engine.
- mysql: MySQL external tables.
- broker: Access external tables through a broker program.
- elasticsearch or es: Elasticsearch external tables.
- hive: Hive external tables.
- iceberg: Iceberg external tables, supported from v2.1.
- hudi: Hudi external tables, supported from v2.2.
- jdbc: external table for JDBC-compatible databases, supported from v2.3.
streaming_preaggregation_modeβ
auto: The system first tries local preaggregation. If the effect is not satisfactory, it switches to the streaming mode. This is the default value.force_preaggregation: The system directly performs local preaggregation.force_streaming: The system directly performs streaming.
system_time_zoneβ
time_zoneβ
transaction_isolationβ
- Description: Session-scoped compatibility variable that records the client-requested transaction isolation level using MySQL-style names. Declared in SessionVariable as
transactionIsolationand annotated with@VariableMgr.VarAttr(name = TRANSACTION_ISOLATION); its presence ensures compatibility with MySQL 5.8 clients. There is a relatedtx_isolationvariable (kept for c3p0 client compatibility). The value is stored per-session to satisfy client/libraries, e.g.,REPEATABLE-READ. Transaction isolation semantics in the engine are managed by StarRocks' transaction subsystem and may not be changed solely by modifying this session variable. - Scope: Session
- Default:
REPEATABLE-READ - Data Type: String
transaction_read_onlyβ
- Description: Used for MySQL 5.8 compatibility. The alias is
tx_read_only. This variable specifies the transaction access mode.ONindicates read only andOFFindicates readable and writable. - Default: OFF
- Introduced in: v2.5.18, v3.0.9, v3.1.7
transmission_compression_typeβ
- Description: Controls the compression algorithm used for transmitting query-related data (RPC/exchange payloads). Use
AUTOto let the system pick a suitable algorithm based on environment (trade CPU for network bandwidth when beneficial). Other valid values are names recognized byCompressionUtils.findTCompressionByName()(for example, codec identifiers exposed by the runtime). For load-specific transmission you can use the separateload_transmission_compression_typesession variable or supply transmission compression in stream-load parameters (HTTP headerHTTP_TRANSMISSION_COMPRESSION_TYPE/ thrift fieldtransmission_compression_type). - Scope: Session
- Default:
AUTO - Data Type: String
tx_isolationβ
tx_visible_wait_timeoutβ
- Description: Session-scoped timeout (in seconds) that controls how long the server waits for a committed transaction to become visible (published) before proceeding. If the visible wait expires, the transaction is treated as COMMITTED but not yet VISIBLE. Materialized view refresh logic (
MVTaskRunProcessor) temporarily sets this variable toLong.MAX_VALUE / 1000to wait effectively indefinitely for visibility and restores the original value after refresh. Whenenable_sync_publishis set totrue, this variable is ignored because the publish wait is derived from the job deadline instead. - Scope: Session
- Default:
10 - Data Type: long
use_page_cacheβ
- Description: Session-scoped boolean that controls whether a query should use the backend page cache. If not explicitly set by FE, the query follows the BE's page-cache policy; if set in the session, FE enforces the session value. The session variable is propagated to the execution layer (e.g.,
tResult.setUse_page_cache) so BE execution honors the decision. Commonly disabled (false) for internal/background jobs (statistics collection, hyper queries, online optimize) to avoid polluting the shared page cache with non-user data β see usages inStatisticsCollectJob,HyperQueryJob, andOnlineOptimizeJobV2. - Scope: Session
- Default:
version (global)β
version_comment (global)β
wait_timeoutβ
- Description: The number of seconds the server waits for activity on a non-interactive connection before closing it. If a client does not interact with StarRocks for this length of time, StarRocks will actively close the connection.
- Default: 28800 (8 hours).
- Unit: Second
- Data type: Int
